Author Topic: Another Fuel Pump Question (Yes, I have used the search function!)  (Read 885 times)
Offline Immortal
  • 1.8 Turbo GTI (AUM)
I'm trying to figure out why I'm seeing several posts regarding the LCR fuel pump.
Can someone please tell me what's so special about it?  :huh: Is it 4bar? Does it have a larger bore outlet? A higher flow rate? What's the deal?!?!
Also, if I were to upgrade what else would need doing?
Cheers!
Offline dom
  • Back in a Mk4
Yes it's 4bar, and yes it has a higher flow rate. What is the rest of your spec? Without other mods and correct mapping you will not need it.
