Author Topic: 3 elec connectors by the throttle on agu  (Read 1944 times)
Offline sharki786
  • GOT BOOST??
« on: 20 August 2013, 22:51 »
Right lads. I fitted the throttle on today, there are 3 connectors 2 for the throttle body and then there is one just there but i cant seem to find out where it goes. Ita an AGU engine code.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
Re: 3 elec connectors by the throttle on agu
« Reply #1 on: 20 August 2013, 23:24 »
I would have a look but its dark so wont be able to see  :whistle:
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 20 August 2013, 23:27 »
Aaah cheers mate. I ment to get a pic of it but like a cok i forgot my phone.
*****MK4 GTI T*****
Offline Jin_C
« Reply #3 on: 21 August 2013, 14:18 »
One connector on the underside of the throttle body in its fitted orientation (Its around 6 pin I think)
Once 2 pin connector for the intake temp sensor that is bolted to the intake manifold
In the same area is also the connector for the camshaft sensor that is bolted to the left-hand side of the head
1.8T AGU, K03s, 007p, pipercross panel filter, G60 + VR6 clutch and flywheel, silicone TIP, decat + boost hoses, JOM coilovers
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 21 August 2013, 17:53 »
cruise control?
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 21 August 2013, 18:38 »
Hmmm. Think i will have a look at the temp intake. Im sure i have fitted that but will have a look in a few mins
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 21 August 2013, 22:20 »
Hmmm weird. That plug wasnt connected and the car started fine. I had it running for ages. I cant find a place for it. You say kts the camshaft sensor? Could you get me a pic of where the cam sensor is mate? If it wernt connected to the camshaft the car wouldnt start or would it?
*****MK4 GTI T*****
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 21 August 2013, 22:43 »
it would start yes. The cam sensor is only two wires though
Offline topher
  • Administrator
  • fully functioning
« Reply #8 on: 22 August 2013, 00:10 »
d'oh
Offline sharki786
  • GOT BOOST??
« Reply #9 on: 22 August 2013, 07:04 »
Love you topher :cool:
Will have a look today after work.
P.s did you get my pm topher?
*****MK4 GTI T*****
