Golf mk4
Wazzzer
anyone used one of these valves??
Topic: anyone used one of these valves?? (Read 1069 times)
dazzaGTi
20 August 2013, 21:38 »
http://www.ebay.co.uk/itm/Stealth-Splitter-Dump-Valve-BOV-for-Audi-VAG-TT-A3-A4-A6-A8-S3-S4-1-8T-20v-Turbo-/221268693007?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3384a4500f
anyone used or using one??
davemk4
Re: anyone used one of these valves??
20 August 2013, 22:09 »
Buy forge 007/8 tried andctested for years and work fantastic. Or even a oem new version valve. These mix valves can cause majorvrunning issues on 1.8Ts
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
dazzaGTi
21 August 2013, 18:16 »
yeah i see that ppl are using the 007/8s. theres such a mixed review on using the atmospheric/ recriculating type valves!
davemk4
21 August 2013, 18:28 »
What year is the golf?
Gti_Jamo
1991 Corrado 1.8 G60
21 August 2013, 18:30 »
I guess it will be roughly the same as the forge split r which usually work well on 1.8t's Although if its dv noise your after just fit a cone filter.
97' Mk3 Golf Gti 2.0 8v Rebuild Project
http://www.golfgtiforum.co.uk/index.php?topic=208865.0
dazzaGTi
21 August 2013, 20:51 »
its a 2001 AUM engine 1.8t .looking at fitting a s2000 filter. just saw these type r ones on ebay and wondered if anyone knew anything about them.
Golf mk4
Wazzzer
