Author Topic: Clear/colourless coolant  (Read 3943 times)
Offline ju571n
« on: 20 August 2013, 21:35 »
Right as my car has a tendency of running g quite hot and the lack of an expansion tank it sometimes spray water out of the boil over and with the coolant being pink keeps making a mess on my clean gearbox and shiny bay.
Now the question is;
I have seen some aforementioned clear/colourless coolant but cannot remember where. Has anybody heard of this or did I dream it??.
Please help. I'm fed up of scrubbing my box with a toothbrush.  :sad:
Cheers J
Re: Clear/colourless coolant
« Reply #1 on: 20 August 2013, 22:22 »
Would it not be better to look at uprating the cooling, bigger radiator maybe.
Offline itavaltalainen
« Reply #2 on: 20 August 2013, 22:29 »
I would investigate why it's running hot.
clear antifreeze / coolant - seen that at ASDA when I raided their DI water supply (need lots of that stuff for work)
Offline tweed
« Reply #3 on: 21 August 2013, 06:07 »
What about twin fan set up from 16v and vr6
Offline GOLF-MK3-GTI
« Reply #4 on: 21 August 2013, 10:07 »
I'm pretty sure the other fan is for aircon.  :undecided:
Offline swainy
« Reply #5 on: 21 August 2013, 12:20 »
If its of any use i have a twin fan vr6 setup, maybe get a bmw top fill rad aswell so youve got a expansion tank.
VW BUSH
« Reply #6 on: 21 August 2013, 13:17 »
Must be cos my 8v has a twin set up :smiley:
Offline ju571n
« Reply #7 on: 21 August 2013, 13:21 »
It's got a brand new rad on it and I fitted a slimline can on the front. I've ordered another fan now. But currently sat in traffic with one 12" it runs at 110. I put a low run switch and cooler stat in. It doesn't like running with the stat so I've taken it out. If the second fan doesn't work I've seen a shiny alloy side fill rad on ebay that would do the trick.
But in the mean time. Second fan should be there when I get home fit that to a switch thethen run some clear coolant from spasda.
BMW rads only work with vr6 coolant hose set up. 8V is plumbed opposite end.
Thanks chaps.
Offline Lurky
« Reply #8 on: 21 August 2013, 15:15 »
blucol do a clear universal antifreeze
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #9 on: 21 August 2013, 15:49 »
The fans are linked together via a drive belt so wont be for aircon.
