Author Topic: Fitting immo 2 bora sport clocks to my aum?  (Read 1841 times)
Offline 150+
« on: 20 August 2013, 10:59 »
How hard or easy is the swap???
Offline davemk4
Re: Fitting immo 2 bora sport clocks to my aum?
« Reply #1 on: 20 August 2013, 11:12 »
Swap easy but need vag tacho to code them in
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Scott D
« Reply #2 on: 20 August 2013, 11:35 »
Not too hard providing clocks in now are IMMO2 not 3 otherwise they'll not fit.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline 150+
« Reply #3 on: 20 August 2013, 13:39 »
How do I tell what mine are??
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 20 August 2013, 17:04 »
what side is your immo symbol
Offline davemk4
« Reply #5 on: 20 August 2013, 17:15 »
weather this is related to just my set up i fitted bora sport immo2 dials to my AUM and have just noticed today my traction control light doesnt light up when ASR button pressed? do i need to activate it on the clocks or something?
Offline 150+
« Reply #6 on: 20 August 2013, 20:43 »
Symbol is on the right at the bottom just above digital clock
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 20 August 2013, 23:26 »
Immo2 then mate, straight ish swap
Have you copied the soft coding from your old clocks?
Offline davemk4
« Reply #8 on: 21 August 2013, 07:22 »
I followed the walk through with pin codes etc everything else works and pre ignition check lights work too but if i floor it and traction control kicks in no lights? Same if i press asr button no warning light
