Author Topic: Sport button as standard on GTD?  (Read 27258 times)
Offline Moskit
« on: 19 August 2013, 22:33 »
I test drove a GTD today. Whilst I was driving the salesman pressed the sport button next to the gear stick and a few options came up on the display. I asked if this was the adaptive chassis option and he said the car doesn't have it.
So is this adaptive chassis? Confused!
Offline monkeyhanger
Re: Sport button as standard on GTD?
« Reply #1 on: 19 August 2013, 22:46 »
Sport adjusts various things like steering weighting, Sound actuator response (on the GTD - does the GTI have an actuator?), throttle response, and if you have DSG it has the speediest recovery of speed to catch up with the car in front after slowdown when the ADC is set.
Offline George k
« Reply #2 on: 19 August 2013, 22:50 »
Both GTD and GTI have sound actuator behind dash as standard
Offline Moskit
« Reply #3 on: 19 August 2013, 23:32 »
Thanks for the reply. So does the sport mode come as standard on all GTD?
How would you know if the car had adaptive chassis control fitted?
Offline CraigW
« Reply #4 on: 19 August 2013, 23:33 »
I may be wrong (bloody hell I should know since I have ACC :grin:) but the only real difference is that with ACC you get a choice of comfort mode which you don't without. All the cars come with variable setups including sport, Eco and normal. That's my understanding but I have been known to be wrong  :wink:
Offline Bill_the_Bear
  • Yes! Wait a minute... No!
« Reply #5 on: 19 August 2013, 23:45 »
DCC (Dynamic Chassis Control) options become available in the main menu.  Won't be there otherwise.
Offline mcmaddy
« Reply #6 on: 20 August 2013, 10:01 »
correct bill. only other thing is that with dcc you get continuously variable damper rates ie sport mode =sport dampers, comfort mode=comfort dampers. you don't get adjustable dampers with the normal driver profile.
Offline Mark V GTD
« Reply #7 on: 18 November 2013, 18:52 »
So the button marked 'MODE' that is located to the front left of the gear stick is common to all GTD/GTI's irrespective of DCC being fitted or not?
« Last Edit: 18 November 2013, 19:51 by Mark V GTD »
Offline corgi
« Reply #8 on: 18 November 2013, 19:51 »
Yes  :smiley:
Corgi
Offline KyleB
« Reply #9 on: 18 November 2013, 20:30 »
Does anyone think the option of comfort would be able to be enabled via vcds? Surely the full suspension system won't be different on cads equipped with DCC?
