Author Topic: turbo chatter since n249 bypass??  (Read 6551 times)
Offline rfn_hodgson
Re: turbo chatter since n249 bypass??
« Reply #30 on: 22 August 2013, 17:36 »
So remove the one bay valve completely ??
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #31 on: 22 August 2013, 20:39 »
does the end of the one way valve go to the DV?
Offline rfn_hodgson
« Reply #32 on: 23 August 2013, 08:18 »
it T pieces off to the dv yea.... i removed the one way valve completely and its still fluttering also had the new piston put in and ive treble checked that ive done the mod right lol
Offline Prawny
  • R-tech power!!!
« Reply #33 on: 23 August 2013, 10:11 »
Simple question then:
Is there a pipe, currently, that runs from your inlet manifold, straight to the top of the DV?
NO T's, no valves, just a length of 3mm vac pipe, from the inlet nipple to the DV, nowhere else.
Do that now if not, as a test, to confirm the DV is working.
Offline Nino
« Reply #34 on: 23 August 2013, 10:40 »
+1
Current - MK6 GTi Edition 35 - Candy White - 3 door
