Author Topic: 16v ignition timing problem  (Read 3297 times)
Offline GeordieChap
« on: 19 August 2013, 19:19 »
Just trying to step up the ignition timing on my 1.8 16v using a timing light seem to the get the marks to line up and then all of a sudden the engine revs go right up and the marks don't align anyone had the same problem?
Offline notenoughtime
Re: 16v ignition timing problem
« Reply #1 on: 19 August 2013, 21:24 »
does it normally rev on its own?
When the revs rise timing alters so marks will be different
Offline GeordieChap
« Reply #2 on: 20 August 2013, 07:11 »
Yeah car revs fine just idles a bit high and there is a slight backfire on down rev so was going to sort timing then idle and check co, just can't understand why all of a sudden the marks align and then off go the revs
Offline raferackstraw
« Reply #3 on: 20 August 2013, 20:03 »
let car warm up, fan should come on twice, then auxillaries off, use the timing light. 6deg btdc.
if it idling high look at bypass screw/isv
search for 16v idling and there are quite a few posts.
also look at mixture/overun cutoff valve
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline Gambit
« Reply #4 on: 22 August 2013, 17:13 »
and make sure the red wire at the coil is disconnected while setting timing, co% & idle
Offline GeordieChap
« Reply #5 on: 22 August 2013, 21:01 »
So it's not only the plug to the ISV I disconnect its also the red wire? Or just the red wire?
Offline GeordieChap
« Reply #6 on: 22 August 2013, 21:33 »
Sorry I meant to say to adjust the idle and co
Offline Gambit
« Reply #7 on: 23 August 2013, 00:17 »
Just the red wire.
