Author Topic: would these wheel bolts be to correct size?  (Read 1315 times)
Offline Nino
« on: 19 August 2013, 11:45 »
Hey guys, been pondering about changing my wheel bolts for ages as I still have the standard oily grubby looking bolts and they look ugly next to my wheels, I done abit of research and I have come up with finding that the Gold mk4 uses M14x1.5 at 28mm???
Had a look on ebay and found...
http://www.ebay.co.uk/itm/20-ALLOY-WHEEL-BOLTS-M14x1-5-28mm-conical-Volkswagen-/250995818484?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item3a70843ff4#ht_2630wt_1200
Im wondering if the bolts with be of decent quality I.E wont break underload and if they are infact the correct size?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline km
Re: would these wheel bolts be to correct size?
« Reply #1 on: 19 August 2013, 11:59 »
hi, can't comment on quality of bolts.
but standard bolts are radius seated, and ones in link are tapered.
might be worth checking your wheels.
And yes those are the correct measurements.
Offline Nino
« Reply #2 on: 19 August 2013, 12:51 »
thanks for the reply, Im using BBS LMR's with standard bolts and not had a problem so best I get the ones you mentioned :)
« Reply #3 on: 19 August 2013, 13:58 »
I am guessing your BBS wheels are reps if so then standard radius bolts will be wrong, 95% of aftermarket wheels use tapered fit so the ones in the link you posted will be correct.
I used these on my alloys: http://www.ebay.co.uk/itm/20-x-M14X1-5-ALLOY-WHEEL-BOLTS-FITS-VW-T4-TRANSPORTER-60-DEGREES-TAPER-No-7-/270915941824?pt=UK_Cars_Parts_Vehicles_Wheels_tyres_Trim_Nuts_ET&hash=item3f13d935c0#ht_1704wt_1328
Offline Nino
« Reply #4 on: 19 August 2013, 20:14 »
yes they are rep wayne, been fitted a year now, not had any problems so far
« Reply #5 on: 19 August 2013, 21:02 »
That might be the case but standard bolts are not locating them as they should be.
Offline dom
  • Back in a Mk4
« Reply #6 on: 19 August 2013, 21:05 »
Wayne is correct, almost all aftermarket wheels need tapered bolts.
Offline Nino
« Reply #7 on: 19 August 2013, 23:43 »
Right I'm gunna get the ones you posted Wayne. Thanks guys  :cool:
« Last Edit: 19 August 2013, 23:48 by Nino »
