Author Topic: anyone no what pipe this is???  (Read 1489 times)
Offline lee1989
« on: 18 August 2013, 22:11 »
as above marked the pipe with an x it goes from the circle to the arrow just want to no what pipe it is as it needs replacing because its split on both ends cheers  :smiley:
Offline George k
Re: anyone no what pipe this is???
« Reply #1 on: 18 August 2013, 22:18 »
Brake servo pipe.  Will go from servo to intake manifold
Offline lee1989
« Reply #2 on: 18 August 2013, 22:22 »
Thought it was something like but didnt want to sound a div  :grin: how important is it?  Does it need changing asap cheers
Offline davemk4
« Reply #3 on: 18 August 2013, 22:25 »
id say it very important as is for your brake servo
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline lee1989
« Reply #4 on: 18 August 2013, 22:28 »
Ok cheers mate think ill get 1 tomorrow then, cheers
Offline lee1989
« Reply #5 on: 18 August 2013, 22:33 »
Just to make sure is it as simple as 1 off 1 on cheers
Offline George k
« Reply #6 on: 18 August 2013, 22:42 »
Yes just put some silicone spray on rubber to make it easier to fit together
Offline lee1989
« Reply #7 on: 18 August 2013, 23:09 »
Ok cheers mate will get it done 2moz cheers
Offline lee1989
« Reply #8 on: 19 August 2013, 22:51 »
Anyone no the part no. for the pipe as cant seem to find it or would it be ok to use silcone pipe cheers
Offline Screech16v
  • MK3 20vt AGU
« Reply #9 on: 19 August 2013, 22:58 »
Get the correct pipe mate where this is concerned,a silicone pipe with that id would probably collapse under vaccum
