Author Topic: why won't my car stop wagging it's tail!  (Read 1819 times)
Offline billytheboot
« on: 16 August 2005, 12:25 »
hello all, simple question with no doubt some simple answer. Pushing the MFA stick twice towards the dash should make the rear wiper activate once, should it not? Instead of stopping it continues.... is my car just excited and showing it's appreciation by wagging it's tail?
Offline Organisys
  • Old and Slow...
Re: why won't my car stop wagging it's tail!
« Reply #1 on: 16 August 2005, 12:30 »
Knackered Relay me thinks ?
Offline Rhyso
« Reply #2 on: 16 August 2005, 12:38 »
Mine is once to activate and once again to stop!! Try it that way.
Offline Haribo!
« Reply #3 on: 16 August 2005, 12:56 »
yeah thats it, once to turn it on then it wipes every few seconds then once to tun it off again, it baffled me when i got my polo cause that did it too and i was used to a fiesta
« Reply #4 on: 16 August 2005, 14:03 »
Thanx, will try that tonight.
« Reply #5 on: 16 August 2005, 14:05 »
Had that on my Driver, was the motor that was fecked.  To check remove linkage off the motor & try again. If it still does it then defo the motor, if not spindle is sticky
Offline Si
« Reply #6 on: 16 August 2005, 21:48 »
I got a similar trouble, my front wipers always turn the washer jets on when i hit a bump! Driving me mad, although im hoping its just the stalk thats at fault?!
Will Mk3 stalks fit straight on as they are bigger and chunkier? :huh:
I LOVE THE SOUND OF CARBS IN THE MORNING
« Reply #7 on: 16 August 2005, 21:53 »
MK3 stalks only fit 90 spec MK2s, i.e. with hazard switch on top of column.  They will fit on earlier MK2s with a bit of effort, you have to replace the ignition housing & do a bit of splicing.
Offline Bazzer
« Reply #8 on: 16 August 2005, 22:14 »
Another small note..... If you push the fecker back and HOLD it, you get a wash with about 3 or 4 wipes, with no 'gaps' in between.... Sometimes the motor limit switch doesn't react quick enough on the 'intermittent' setting to catch the wiper in the 'park' region though. WD40 is your best mate here.......
Bazzer
