Author Topic: Will MK5 touch sceen double din fit?  (Read 1385 times)
Offline JWebb
« on: 18 August 2013, 15:34 »
As Above ?
Will the touch screen sat nav fitted in some mk5 golfs fit and work in my mk4 without too much trouble?
it's this one but second hand?
http://www.dhgate.com/product/large-8-volkswagen-passat-car-dvd-gps-navigation/162989040.html
Thanks
Jack.
Offline mcgee9t2
Re: Will MK5 touch sceen double din fit?
« Reply #1 on: 18 August 2013, 16:33 »
that isn't a mk5 golf touch screen that's aftermarket.... (or iv never seen that one and it doesent look oem to me.)
yeah will fit if you get the correct size double din cage. and the correct wiring harness
Offline George k
« Reply #2 on: 18 August 2013, 16:39 »
Don't think it will fit as its not correct double din size and has screw mounting brackets on each side making it fit mk5 and other models listed on listing
Offline JWebb
« Reply #3 on: 18 August 2013, 16:49 »
Cheers I was toying with the idea but not sure if I'll bother
it loads up with the VW symbol so assumed its oem but possibly not.
Jack
Offline mcgee9t2
« Reply #4 on: 18 August 2013, 16:56 »
mines the same size as that and has screw mountings, so can be made to fit
Offline dom
  • Back in a Mk4
« Reply #5 on: 19 August 2013, 21:26 »
Mk5 factory head units are wider than double din, I've seen pictures of them fitted so it is possible but it looks crap.
Offline sveed1.8T
« Reply #6 on: 19 August 2013, 23:12 »
Glad that someone has said it! :grin:
