Author Topic: diverter valve  (Read 2609 times)
Offline mcgee9t2
diverter valve
« on: 18 August 2013, 12:52 »
if I was to buy a 007p with the yellow spring, would I be ok to run on my car for a month or so...
car is currently not maped. however hopefully I will be getting a hybrid turbo and map next month..
Offline shiloh
Re: diverter valve
« Reply #1 on: 18 August 2013, 13:19 »
As far running the car goes, not 100% sure but would probably be ok if  you took it easy. If you pay the Extra £10 you can get the 008 which comes with yellow green and blue springs + spacers, which I think is totally worth it tbh. If you want to get a 007p and are worried about the spring pm your address and I'll post down my green one to you and you can post it back once you get it mapped.
Offline sharki786
  • GOT BOOST??
Re: diverter valve
« Reply #2 on: 18 August 2013, 13:23 »
Now thats what i call generosity!!!  :cool:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline davemk4
Re: diverter valve
« Reply #3 on: 18 August 2013, 18:41 »
is there any improvment over the 007 to the 008?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline paultownsend
Re: diverter valve
« Reply #4 on: 18 August 2013, 19:23 »
Go to Vw/TPS and buy a 710N diverter valve. £35.
Is is the best valve for the car. I swopped from a 008 as with a green spring it wouldn't close, and yellow it had trouble opening.
Search the web. Much discussion and testing. OE is best.
Rs8 and Porsche 997 twin turbos both use this very same updated valve.
Offline mcgee9t2
Re: diverter valve
« Reply #5 on: 19 August 2013, 07:31 »
any idea what psi these 710n dv are rated for?
Re: diverter valve
« Reply #6 on: 19 August 2013, 10:46 »
I ran my Octavia on a yellow spring for a week or so before it was mapped all ok.
Offline WadGTI
  • Golf GTI'er
Re: diverter valve
« Reply #7 on: 19 August 2013, 12:36 »
I have been looking at a 007p for my stock AUQ.
After seeing your post and reading up about the 710n...think I am going to go for this and forget about the forge until I am running serious power.
Thanks
Re: diverter valve
« Reply #8 on: 19 August 2013, 18:58 »
You have made the correct choice sir.
Psi has nothing to do with it. As the boost system acts on the side and top of the DV. It will never push open. Its holding it closed!!! It's vacuum that opens the valve, and that does not change after remap/new turbo.
The OE DV has the correct spring for the engines vacuum.
Offline topher
  • Administrator
  • fully functioning
Re: diverter valve
« Reply #9 on: 19 August 2013, 19:16 »
pretty sure its gone to 710P now
