Author Topic: throttle switch  (Read 1399 times)
Offline marcogolfo
  • Freelance Web Design, Logo Design etc email me
throttle switch
« on: 16 August 2005, 11:41 »
How do i diagnose if my throttle switch is working correctly?  What symptoms would i get if it wasn't and how would i test it.  Just that I seem to be getting like a slipping clutch effect but only when im absolutely gunning it
Offline mikegolfgti
Re: throttle switch
« Reply #1 on: 16 August 2005, 11:57 »
is it the full throttle switch on a digifant, the easiest way to check it to have the engine running open the throttle manually to about 2000rpm then press in the switch if the revs change, i think the revs should drop, it works  :smiley:
Offline marcogolfo
Re: throttle switch
« Reply #2 on: 16 August 2005, 12:48 »
naaah its on the early k jet 16v, when the throttle closes there is like a little red button that it knocks against.  I'm presuming this is the throttle switch? :undecided:
Offline mikegolfgti
Re: throttle switch
« Reply #3 on: 16 August 2005, 17:30 »
im guessing thats the idle switch if i clicks when the throttle is closed, id say the easiest way to test without proper tools is to dissconect it when the engines running, i would have thought thered be a connector plug near the switch, not too sure on the 16vs tbh
Offline marcogolfo
Re: throttle switch
« Reply #4 on: 17 August 2005, 09:36 »
im with ya cheers
Offline Deefadog
  • Mk2 16V (November 89)
Re: throttle switch
« Reply #5 on: 18 August 2005, 11:05 »
Just dis-connect it and see :) it does not make much difference on mine?
There is a test in the haynes for this! It is real awakward to do if you dont take the switch out with the bracket! and get a mate to hold the multimete pins in for you, so much easier ;)
Also you might want to spary some wd 40 down the accelerator cable just to lube it up!
Judderi
Re: throttle switch
« Reply #6 on: 18 August 2005, 13:55 »
If you wanna test the red button you can see then start the engine and hold the throttle open a little by hand. Then press the button in, if the revs drop then its working ok.
Offline Gambit
Re: throttle switch
« Reply #7 on: 19 August 2005, 17:06 »
u need to hold the rev's above 2krpm then hit the button. rev's will drop & u will here the overrun valve opening also
