Author Topic: creations 3mm silicone.  (Read 2915 times)
Offline sharki786
  • GOT BOOST??
« on: 16 August 2013, 20:55 »
Got 3mtra of creations motorsport 3mm sillicone, i wanted to know is it ok to use it from under the manifold? Think it goes to the fuel.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Nino
Re: creations 3mm silicone.
« Reply #1 on: 17 August 2013, 07:14 »
If you mean the fuel reg and all the small piping underneath then yes you can use it :)
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 17 August 2013, 09:25 »
You sure the fuel wont eat through the pipe?
*****MK4 GTI T*****
Offline Chris#101
« Reply #3 on: 17 August 2013, 10:56 »
No because its not fuel that goes through the pipe it's a vacuum  :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 17 August 2013, 13:44 »
DOH!! Stupid me!
*****MK4 GTI T*****
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 17 August 2013, 14:37 »
 :grin: :grin: :grin: :grin:
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 18 August 2013, 08:10 »
Righty then peeps. Got the stuff back on the engine. Now i see a pipe coming off the dv and goes to a fat silver pipe on the back of the engine, looks part of the turbo. Whats that pipe called?
Pic:
Thanks
*****MK4 GTI T*****
Offline Nino
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 18 August 2013, 11:54 »
http://www.creationsmotorsport.com/product-detail.php?pid=411  :cool:
Nice one. Dont people normaly delete that? Or is n75 diverter valve??
*****MK4 GTI T*****
Offline dom
  • Back in a Mk4
« Reply #9 on: 19 August 2013, 21:28 »
People usually delete N249 and N112 valves, you want to keep the N75 :wink:
