Golf mk4
Wazzzer
hi pitch noise
Topic: hi pitch noise (Read 1175 times)
dstv
GTI forum regular
hi pitch noise
14 August 2013, 21:51 »
Hi guys
I have a issue.....when in stand still and i do a full turn lock turn to the right, start moving a weird hi pitch noise appear. Now the noise go's away when speeding up.. the mechanic said its the steering rack and want to replace it..i dont think the mechanic gave my car a proper once over and is questing tbh.
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
ant_gti
GTI forum regular
mk3 20v turbo
Re: hi pitch noise
14 August 2013, 21:58 »
chances are its just a typical noisy vw power steering pump,mine has been a bit moany for ages. Has it been run low on fluid?
rio_gti
"i'm not spending any money on it" Got a Hybrid!
Re: hi pitch noise
14 August 2013, 23:15 »
Has it been lowered?
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
dstv
GTI forum regular
Re: hi pitch noise
15 August 2013, 08:20 »
Yes its been lowered and the noise started not long after that
rio_gti
Re: hi pitch noise
15 August 2013, 09:13 »
It'll be the drive shaft on the drop link!! I gotta sort mine out it does it too!!!
Not at every right turn thou only when parked in a curtain spot and pull off to the right....
Also I found it might also be rubbing on the oil return pipe
Nino
Re: hi pitch noise
15 August 2013, 10:20 »
mine does this but only if i go full lock, mine is also lowered, and your mancanic is an idiot for telling you that you need a new steering rack, there is a different antiroll bar you can buy to counteract this problem, whiteline or something.
Like my badge? Get one here:
https://www.golfgtiforum.co.uk/index.php?topic=291134.0
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35 - Candy White - 3 door
Golf mk4
Wazzzer
hi pitch noise
