Author Topic: Turbo whine  (Read 981 times)
Offline km
Turbo whine
« on: 14 August 2013, 08:18 »
Hi,
I've just had a k04-001 installed on my AGU.
Noticed that there's a slight whine on low boost. And when I say low I mean when the boost gauge comes off vacuum to 0-4psi. The whine is quiet and you'd never hear it with the radio on.
As the car isn't mapped yet I haven't let boost build up any higher as I have n75 disconnected.
But I have on occasion plugged it in to see if it whines on slightly higher boost. It either disappears or is not noticeable.
Anything to worry about? Thanks
Offline km
Re: Turbo whine
« Reply #1 on: 15 August 2013, 20:41 »
anyone? :rolleyes:
Offline davemk4
Re: Turbo whine
« Reply #2 on: 15 August 2013, 20:51 »
was the turbo recon or used?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline km
Re: Turbo whine
« Reply #3 on: 15 August 2013, 22:56 »
brand new + genuine.
