Author Topic: Some (hopefully) interesting titbits for the GTI/GTD  (Read 33572 times)
Offline monkeyhanger
Re: Some (hopefully) interesting titbits for the GTI/GTD
« Reply #10 on: 13 August 2013, 11:15 »
Lane assist is camera based.
I was thinking that highbeam assist would operate on the same sensor that the auto lights operate on (which is on the inside of the windscreen at the base of the rear view mirror stalk attachment) if no further hardware is required. If further hardware is required then perhaps it is an enhanced light sensor, or additional one somewhere.
As with the XDS on the Scirocco - VW aren't shy on charging you for an option that requires only VCDS activation.
Offline corgi
« Reply #11 on: 13 August 2013, 12:08 »
I suspect the wheel base difference is either a mis-print or more likely due to differences in suspension geometry...
It is only 6mm, the shells will be the same...
Corgi
Offline George k
« Reply #12 on: 13 August 2013, 19:56 »
High beam assist uses a black and white camera behind mirror
Offline Raffe
« Reply #13 on: 13 August 2013, 20:50 »
No it will be the bumper design, look where the measurements are taken from, chassis will be standard throughout range.
Ricepop
« Reply #14 on: 13 August 2013, 21:10 »
The bumpers are irrelevant its the wheelbase that is different. Probably the best explanation is that the non GTI model shown doesn't have the independent suspension causing a longer wheelbase.
Offline Jimble
  • Moderator
« Reply #15 on: 13 August 2013, 23:09 »
Offline George k
« Reply #16 on: 14 August 2013, 09:30 »
 Knew I was :smiley: just done a course based on GTI/GTD
Offline dippy_x
« Reply #17 on: 14 August 2013, 10:21 »
GeorgeK,  do you know if the voice activated audio requires additonal hardware as well?
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
« Reply #18 on: 14 August 2013, 10:26 »
Could you build us one quicker from spares than VW Wolfsburg can supply since being on that course?  :tongue:
Offline matchboy
« Reply #19 on: 14 August 2013, 10:29 »
Any word on your car being built this week MH or have you not checked?
Audi RS5 2018
Gone: BMW M4 LCI Competition Package
Previous: Mk 3 Audi TTS, Porsche 981 Cayman S, Mk 7 Golf R, Mk 7 GTI, Mk 6 GTI, Mk 5 GTI and so on....
