Author Topic: Dash warning lights not working  (Read 1327 times)
Offline Lurky
« on: 12 August 2013, 15:11 »
hi all just after some advice my warning lights seem to have stopped working ie oil warning / hanbrake warning etc i thought it was down to my ignition switch as it was a bit worn i have replaced the switch but still no lights when ignition is switched on checked all fuses they seem fine is there anything else i should take a look at or is it a possibility they are bust and the clocks need replacing
Offline dibs1980
Re: Dash warning lights not working
« Reply #1 on: 12 August 2013, 20:42 »
Maybe best take the dash cluster out and change the bulbs there is a guide on here on how to remove the cluster
Offline Lurky
« Reply #2 on: 13 August 2013, 10:16 »
there soldered led's  :sad:
Offline dibs1980
« Reply #3 on: 13 August 2013, 17:07 »
Oh right mines are bulbs
