Author Topic: things people would suggest to do before remap  (Read 1739 times)
Offline wsmith
« on: 11 August 2013, 15:39 »
my golf 1.8t AUM is getting remapped next week im just wondering what people would suggest doing to the car before hand. its had 4 new coil packs from vw put on ,ive checked all pipes and replaced ones that were damaged ,ive just done 500 miles in it last week on holiday and it never missed a beat .
 -oil , filter  change ?
- new spark plugs ?
Offline mcgee9t2
Re: things people would suggest to do before remap
« Reply #1 on: 11 August 2013, 15:47 »
depends what you want. if your looking to modify it a lot and get maximum power or just wanting to keep it relatively standard and just get a map..
if you want just a map then...
full service (unless its just been done less than 5k ago. check all sensors and make sure its running spot on, stick a fault code reader on to make sure theres no faults, proberbly a uprated dv anyway cause don't think the standard ones can hold much pressure...
if your wanting to mod and get max power
the above & fmic, uprated boost hoses, uprated dv, full exhaust system including down pipe, induction kit/panel filter... then if you were wanting to go further injectors, hybrid/big turbo etc..
aslong as you have it running sweet when it goes in im sure you will come out with a huge grin on your face...
Offline james18t
« Reply #2 on: 11 August 2013, 18:45 »
Raise your coilovers too if it's low or it won't go on the rollers  :smiley:
Offline westylakey
« Reply #3 on: 11 August 2013, 22:30 »
Aum charge pipe to agu charge pipe.
Oil pump/pickup pipe
2001 AUM 1.8T, Remap, Forge 008, AGU Charge Pipe, 3" Decat to 2.5" Jetex System, S2000 Filter Inc H/S
Offline mar_k
« Reply #4 on: 12 August 2013, 18:00 »
Take a couple of spare coil packs as old ones can often go during or just after mapping,
Offline paultownsend
« Reply #5 on: 13 August 2013, 18:33 »
When I was in your position I made sure the car was fully serviced.
As soon as I got the car home-
Cam belt and all rollers/tensioners.
Oil change.
Sump off and new pick up.
Another oil change (synta platinum)
G12 coolant , water pump, stat.
Brake fluid.
Platinum plugs.
All the above from VW/TPS.
I also renewed all vacume hoses, carbon canister delete, and fitted a catch can.
The trip to Midland VW then showed it had the wrong throttle body and a weak actuator.
The Car was then safely mapped after a TB adaption and tighten of the actuator. And I'm pleased with the results.
I treated the visit to midland VW as a health check. And I have a healthy car. Even at 100k compression is 195psi on all cylinders. Check yours also.
I would also fit a boost gauge. And if you have time get a free copy of VCDS and did one logs.
Good luck!
Offline wsmith
« Reply #6 on: 13 August 2013, 19:53 »
thanks for the help  :smiley:peeps ive put a 007p on it and fitted a boost gauge im fitting new spark plugs tomara, i was looking at doing the pick up pipe with the next service in a few weeks but i might do it at the weekend, ive got the airbox smoothed out with pipercross filter in it and was looking at getting the r32 snorkel and the bit that goes behind the head light, i cant wait to have it remapped
i was also advised to get a 4 bar fuel regulater ?? whats peoples thoughts on that
Offline mcgee9t2
« Reply #7 on: 13 August 2013, 20:11 »
not needed until you get big power. i.e stage 3
Offline wsmith
« Reply #8 on: 13 August 2013, 21:07 »
ok cheers
