Golf mk3
hardmonkeys
Gti fail mot on emissions!!!!!!!
Topic: Gti fail mot on emissions!!!!!!! (Read 2405 times)
anogg3
Just got here
09 August 2013, 17:43 »
Need some help quite quickely please car failed mot on emissions!!!! Lambda 0.936 and co 1.935!!!!
Anu ideas as what I can do?
It hasn't been serviced yet and has been stood for a while as ive not used it since buying just done some work on it.
gazareth
Re: Gti fail mot on emissions!!!!!!!
09 August 2013, 17:59 »
try changing oil/spark plugs and air filter.
Gti_Jamo
1991 Corrado 1.8 G60
09 August 2013, 18:08 »
Also get a code reader on it incase anything obvious comes up.
97' Mk3 Golf Gti 2.0 8v Rebuild Project
http://www.golfgtiforum.co.uk/index.php?topic=208865.0
gazpowells
09 August 2013, 19:40 »
give it a good service and take it for a hard drive before the retest worked perfect for my last mot when i failed emissions
Anniversary chic
09 August 2013, 19:51 »
as said you can also buy some stuff think it goes in the fuel to stop smoke its a short term fix but might help you get a ticket
madmanmart
09 August 2013, 20:03 »
What Cat is on it?
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Foreveryoungaus16v
Reply #6 on:
09 August 2013, 20:16 »
Quote from: madmanmart on 09 August 2013, 20:03
What Cat is on it?
Your car is looking
KW V2, TEAM DYNAMICS PRO RACE 1.2, EIBACH ARBS, DS 2500 PADS, BLACK DIAMOND DISCS, LIGHTENED FLYWHEEL, CHIPPED ECU, VIBRA TECHNIC MOUNTS, JETEX DECAT, FULLY POLYBUSHED
163 BHP (TSR POWER RUN)
Jasikasisback
Reply #7 on:
13 August 2013, 08:25 »
as above
oil and filter right before the test.
Or move to a country with no emissions testing.
GOLF-MK3-GTI
Reply #8 on:
13 August 2013, 23:33 »
I'm sure the Ecu temp sensor can cause the engine to run rich if faulty as it can't sense if engine is cold or hot.
Len
10k hero
Reply #9 on:
14 August 2013, 13:09 »
As above but also buy a new CAT and lambda sensor
www.sas.org.uk
www.the-ace.org.uk
Golf mk3
hardmonkeys
