I have been plagued with an intermittent boost issue for the last couple of months. Basically it's like a huge flat spot in my boost curve, but it's not always there. When it happens it boosts normally to around 3k, then all boost vanishes (very noticable but no fault codes) until it reaches 4k, at which point boost comes back in full & remains into the red. It seems more noticeable when under heavy load (such as accelerating uphill).
I have done everything I can think of, however it disappears for a day or two then returns.
It's had:
MAF
Throttle body clean & realign
Fuel filter
Plugs
2.0T coils (due to a separate misfire fault)
Decat (due to separate issue)
Temp sensor (Seperate fault)
Timing belt & water pump (was due)
I've also run it with fuel cleaner & injector cleaner since the issue with the fuel filter.
I'm stuck! Could be an N75 issue or possibly the fuel pump, but the intermittent nature & lack of fault codes has me completely lost!!!
A remap might cure it, but I want it running correctly before it goes in.
Any help or bright ideas would be gladly appreciated!
