Author Topic: mk2 golf 16v with 20vt - rev counter inop  (Read 1727 times)
Offline awallis
« on: 07 August 2013, 19:13 »
hi got a 16v golf with a 20v turbo lump in it. When I first brought the car the revs worked fine but i've had the speedo out since. And now my revs are inop. I've found the air pipe that goes onto the back of the rev counter but cant find where it pushes into in the engine bay. The pipe is only 5/6inches long so wont reach far. Any help?
Offline Gambit
Re: mk2 golf 16v with 20vt - rev counter inop
« Reply #1 on: 09 August 2013, 08:23 »
The vacuum pipe doesnt operate the rev counter it works via a signal from coil on a 16v but you will have a different setup as its a 20v. What ecu are you running?
Offline awallis
« Reply #2 on: 10 August 2013, 13:12 »
Ah I see.
Running an MBE 992 ecu.
Offline Gambit
« Reply #3 on: 10 August 2013, 14:33 »
There should be a feed wire running from ecu to the rev counter wire which im guessing has pulled apart when you removed the clocks.
So just a case of tracing wires :(
