Author Topic: Remapped 1.8t anniversary  (Read 2985 times)
Offline Nino
Re: Remapped 1.8t anniversary
« Reply #10 on: 07 August 2013, 23:23 »
Jake your running a standard DV you need to upgrade it. The standard DV can only run upto around 11psi or 1.5 bar. A remap takes your boost to about 18-20psi and your standard DV will buckle under that pressure. I'd advise you get a forge 007p or 008.  You will also need a yellow spring installed
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline jake-w07
« Reply #11 on: 08 August 2013, 12:30 »
Okay mate will get one purchased asap, where's best place to buy them from ?
Silver Golf GTi 25th Anniversary 1.8T - Milltek Non Res Catback - 3" Downpipe & Decat - Forge 007p - ITG Cone Filter - Custom Remap
Offline Nino
« Reply #12 on: 08 August 2013, 12:54 »
I got mine from ebay, however there are many places that sell them, if you can look to buy a brand new one and get the 008 and expect to pay about £130
Offline jake-w07
« Reply #13 on: 08 August 2013, 14:57 »
From what I've read in the dump valve thread the 007p is better for my car is that right ? Anywhere other ebay I could try, would like one before weekend if poss
Offline AD1.8T
« Reply #14 on: 08 August 2013, 15:34 »
Awesome gti and dpm performance both do next day delivery
Offline jake-w07
« Reply #15 on: 08 August 2013, 17:54 »
picked car up from garage about an hour and half ago and shes running sweet just like she was a couple days ago, turns out was just a pipe blown off somewhere on the inlet!! they put the pipe back on cleared all faults and job done, sourced a black forge 007p with yellow spring from autograph in burnley and pick it up tomoro theyve done it me for the same as there going for on ebay so im chuffed, should be straight forward enough to do shudn't it ?
Offline brewey
« Reply #16 on: 08 August 2013, 17:59 »
Dead easy to fit mate. Remove engine cover undo the jubilee clamps holding the standard valve and replace it with you forge valve.
If you still aren't sure there is a PDF on the forge website showing you exactly how too.
2000 1.8T ARZ - OEM+
Offline jake-w07
« Reply #17 on: 08 August 2013, 18:00 »
okay niceone pick it up in the morning might even do it on my dinner  :grin:
Offline Nino
« Reply #18 on: 08 August 2013, 19:06 »
Great news, u should both hear a nice difference and feel better throttle response once its on ;)
