Author Topic: Help - Fuse diagram  (Read 2666 times)
Offline Pobby2005
Help - Fuse diagram
« on: 15 August 2005, 16:06 »
Good afternoon all, I was wondering if any of you could help me out. I have a 99 MK4 2.0 GTi and the Air Con ( Non Climate ) has suddenly stopped working and the light on the push button has gone off too... I believe this is just a fuse that's gone, unfortunately both the fuse diagram and the little card that fits in the fuse flap are missing. Can anyone Email or fax me a copy of the diagram or even just tell me which fuse box and number needs to be changed?
I would appreciate any help you can offer.
Thanks
Pobby
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: Help - Fuse diagram
« Reply #1 on: 15 August 2005, 20:12 »
Just check all the fuses, you should be able to see if 1 has blown
 :undecided:
Sugar79
« Reply #2 on: 16 August 2005, 15:07 »
it should be fuse number 5... but check threw them all to make sure  :cool:
Offline Pobby2005
« Reply #3 on: 17 August 2005, 17:53 »
Hello, again. I've checked all the fuses in side of the dash... Does anyone know where else I might find the Air Con conpresser fuse?
Pobby
Offline Pobby2005
« Reply #4 on: 13 September 2005, 14:42 »
Hello All, I'm still struggling with this one....
Is there another fuse box other than the one in the side of the dash for a 1999 2.0 GTi?
I managed to locate a diagram showing the Air Con fuse but it doesn't match the lay out in the dash.
Can anyone help?
Pobby
Offline GTI EDITION (aka LTD)
« Reply #5 on: 13 September 2005, 15:18 »
If my memory's correct the diagram for the fusebox on the plastic cover is a mirror image, ( ie  back to front ) possibly because it was printed for the lefthand drive models  :undecided:
The other fuses including thermo fuses will be found behind the relay plate which is situated up behind the driver side lower panel which holds the lighting switch .
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
