Author Topic: mk4 turbo oil light  (Read 1551 times)
Offline 1toomanyuk
mk4 turbo oil light
« on: 05 August 2013, 22:26 »
brought mk4 turbo code arz to convert corrado to 20v picked up today oil light was on and check oil on dash fillled it ran it on spot check oil now not showing but oil light staying on engine ran smooth idled fine so wondering is there sensor that may need resetting or something many thanks in advance
Offline smokiedee
Re: mk4 turbo oil light
« Reply #1 on: 05 August 2013, 23:30 »
if its the same as my aum it has a microswitch in the bonnet catch that fails i managed to follow the wiring press mine and it resets the check oil light as even if u top it up the light won't go out until the bonnet has been opened.
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 06 August 2013, 06:14 »
I would check the pickup pipe while im at it. Only £12 from tps
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline smokiedee
« Reply #3 on: 06 August 2013, 11:21 »
How much is a oil pump from tps also I might just do both
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 06 August 2013, 18:04 »
About 12 no more than 20. It comes with a s
O-ring seal aswell
*****MK4 GTI T*****
« Reply #5 on: 11 August 2013, 10:28 »
Not sure if the ARZ has a level sensor in the sump but that might be worth checking as well.
Offline brewey
« Reply #6 on: 11 August 2013, 12:33 »
ARZ does indeed have a level sensor in the bottom of the sump (or at least mine does).
2000 1.8T ARZ - OEM+
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 13 August 2013, 10:12 »
Sorry just re-read my reply. Not sure how much the pump is mate.
*****MK4 GTI T*****
