Author Topic: Battery draining  (Read 2194 times)
Offline scott-stainton
Battery draining
« on: 01 August 2013, 21:55 »
Hi guys,
I'm new here so first off, hello!
Secondly, I recently bought a 16v mk3 as a project car. It's not been ran on journeys as its sorn but while I've been sorting the cooling system this week iv noticed the battery is discharging daily. Is there any easy way to test if anything is draining the battery?
Scott
Offline Bellend
Re: Battery draining
« Reply #1 on: 01 August 2013, 22:37 »
Get an amp meter and remove the positive terminal, put that in between the positive terminal and the positive post on the battery. Read the amp drain. Shouldn't be much at all. Not even 1 amp.
If it is higher than say 0.1 amps (just guessing here as plenty of cars are different) get someone to start pulling fuses one by one until it drops. Then you'll know which circuit it is.
Currently doing a Mitsubishi that has a 9amp draw!
It's an iPod adaptor kit killing the battery.
Where all my moneys went.
Offline gazareth
« Reply #2 on: 01 August 2013, 22:38 »
check that the glovebox or boot light isn't staying on.
« Reply #3 on: 01 August 2013, 22:41 »
Il do all that in the morning guys cheers for the advice!
Offline itavaltalainen
« Reply #4 on: 02 August 2013, 20:58 »
Did you buy that 16v from someone in Brough?
Think the colour was mystic blue? Seen it a few times driving through there.
Offline tweed
« Reply #5 on: 02 August 2013, 21:17 »
Sounds like a dead battery to me.
« Reply #6 on: 03 August 2013, 14:30 »
No i bought it from someone in Barnard Castle, its a silver one.
And found the problem guys its the battery, cheers again for the help!
