Author Topic: New track control arm but still loads of play  (Read 3239 times)
Offline weazgti
Re: New track control arm but still loads of play
« Reply #10 on: 04 August 2013, 14:06 »
Cleaned bolt, oiled and left the sleeve out.
Torqued up lovely with no play or knocking. I take it the sleeve is just a guide  for fitting so is safe to leave out?
TT bushes sound good. I d like it a bit sharper on turn in really.
Thanks for your help guys
Offline Gambit
« Reply #11 on: 04 August 2013, 23:34 »
The sleeve is nessecary for std rear bushes as it is used to centre the bush. The bolt is not a tight fit through the bush and hence
 the arm will move under load albeit only a few mm.
As said prev, if you use mk1 tt bushes you do not need the sleeve to centre the bush
alternativily just trim the sleeve so it sits flush with top and bottom of bush.
Offline Diamond Hell
  • Opinions я Us
« Reply #12 on: 05 August 2013, 06:31 »
I think it's one of those things that got revised, which meant the sleeve became unnecessary.  I've tried fitting them with replacement bushes and not been able to either get the sleeve in, or get things tight.  The TT bush takes all of this away anyway, as you've pointed out :)
