Author Topic: Golf Gti 16v Technical Question  (Read 2466 times)
Offline xionsolaris
« on: 31 July 2013, 19:09 »
Hello I have purchased a valver I did have a gti 8v I seem to have a engine bay noise I think I have identified the problem I just need a 2nd opinion and a relative fix to solve this issue here are the images thanks.
Uploaded with ImageShack.us
Any help will be appreciated thanks
Offline Screech16v
  • MK3 20vt AGU
Re: Golf Gti 16v Technical Question
« Reply #1 on: 31 July 2013, 20:00 »
Tensioner idler looks like its been bent and not running true with the belt,replace the tensioner. :smiley:
Offline xionsolaris
« Reply #2 on: 31 July 2013, 20:16 »
So I need to replace the arm and the idler pulley does the altenator still tension the belt on the abf engine thanks
Offline gazareth
« Reply #3 on: 31 July 2013, 20:34 »
maybe the alternator is wrong fitting? or tensioner assembly is bolted to engine squint? the tensioner arm does look bent in pic but its hard to be sure from that angle.
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 31 July 2013, 22:45 »
Alternator is fixed on abf as per tensioner,agree with above check alt is correct and the tensioner is bolted up square,it still looks bent to me though!  :wink:
Offline xionsolaris
« Reply #5 on: 01 August 2013, 06:23 »
Thnks for ur help
Offline xionsolaris
« Reply #6 on: 03 August 2013, 10:46 »
Now I have removed fan belt and I have found out that the tensioner arm can slide out a bit so now the pulley dosent rub is this normal my car has only 110k on the clock has anyone else noticed this with the tensioner
Offline madmanmart
« Reply #7 on: 03 August 2013, 11:14 »
Shouldn't do that, sounds broken  :wink:
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #8 on: 03 August 2013, 14:35 »
Certainly can't remember mine having side movement in it.
Offline xionsolaris
« Reply #9 on: 03 August 2013, 19:40 »
It lasted one drive and it went back no one stocks the part as its part of the bracket that holds the altenator and pas pump
