Author Topic: Help, broken rotor arm now won't run  (Read 2940 times)
Offline Craigwilson
« on: 30 July 2013, 21:47 »
Okay so I was just driving along and suddenly the car cut out and would not start, I took the dizzy cap off as the rotor arm had broken it two, so I got towed home and put a spare arm in had on and it won't start, I loosened the distributer and turned it anti clockwise and if I do that while a mate turns it over it start but it runs rough and cuts out and if I try turn it to where it should be with the timing light it just dies and misfires and backfires, all I can think of is the dizzy cap as the inside of it was a mess but I don't imagine it would cause this, help anyone !?
Offline Diamond Hell
  • Opinions я Us
Re: Help, broken rotor arm now won't run
« Reply #1 on: 30 July 2013, 21:58 »
Of course it would cause it - the rotor arm's just disintegrated inside it!
Replace the arm and cap with new.  Timing shouldn't need to be adjusted.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #2 on: 30 July 2013, 22:25 »
 ^^ Ditto
Thom
Offline Craigwilson
« Reply #3 on: 30 July 2013, 22:46 »
Will do tommorow, just needed to be assured, but what is it that about the cap that would make it do that
Offline danny_p
« Reply #4 on: 30 July 2013, 23:03 »
as it's probaly a mess inside the dizzy cap that would explain it,
high voltage electricity is funky stuff it allways finds what it thinks is the easyest way to ground,  may not be the shortest route and  often prefers any route that dosent involve the spark plug,  a hareline crack in the dizzy cap acan cause chaos and a rotor arm flying apart is going to do at least that much  damage
all the VW's have gone bar 1.
Offline gazareth
« Reply #5 on: 31 July 2013, 00:00 »
make sure to buy a proper bosch cap and rotor arm if you can. some of that cheap stuff is awful. check around the hall sender for fragments of rotor arm to. you never know. could be running like a champ once the new parts are on.
Offline Craigwilson
« Reply #6 on: 31 July 2013, 00:43 »
It was a cheap cap that was on it I could tell it just wasn't of quality. The cars been running so well too I've not touched it in 2 weeks
Offline Craigwilson
« Reply #7 on: 31 July 2013, 09:21 »
Okay help new arm and dizzy still won't run !!!! Need urgent help
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #8 on: 31 July 2013, 13:08 »
Check the wiring to the hall sender. It's a plug with three wires that attaches to the dizzy. they tend to break as they get covered in oil.
Offline Craigwilson
« Reply #9 on: 31 July 2013, 13:44 »
It's okay I've tried another distributer in it and same problem, it only runs when timing is advanced and even then it runs terrible
