Author Topic: Flickering handbrake light.  (Read 3129 times)
Offline Waspy
« on: 29 July 2013, 16:23 »
So was driving along today and the handbrake light started to flicker. It is pretty random, it isn't constantly flickering, just at random points. Any ideas? If nothing else it is distracting.
« Last Edit: 29 July 2013, 16:41 by Waspy »
Offline Simeon
Re: Flickering handbrake light.
« Reply #1 on: 29 July 2013, 17:32 »
Have a look at the switch under the handbrake cover and see if the wiring is ok
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #2 on: 30 July 2013, 01:31 »
+ 1
Try and clean the contacts on the switch - can be a pain as it's riveted to the handbrake lever - bit of WD40 and some emery paper - same principle as the door window switch, so very simple technology, just need a bit of time and patience!
« Last Edit: 30 July 2013, 01:33 by X4MGS »
For More Info Click To See;
Offline George k
« Reply #3 on: 30 July 2013, 07:27 »
Check brake fluid level and condition if pads
Offline Craigwilson
« Reply #4 on: 30 July 2013, 22:48 »
The hand brake light also acts as a brake fluid warning light
Offline gazareth
« Reply #5 on: 31 July 2013, 00:11 »
yeah the low brake fluid warning and the handbrake warning are linked in to the same bulb. so could be either.
Offline Waspy
« Reply #6 on: 31 July 2013, 00:19 »
Great, thanks guys, ill take a look tomorrow.
Offline Waspy
« Reply #7 on: 31 July 2013, 10:45 »
Brake fluid is on the low side by the looks of it, can I just top it up, or do I have to bleed the whole system? Brakes arnt something I want to get wrong...
Offline vr6south
« Reply #8 on: 31 July 2013, 10:55 »
Just simply top it up from the resevior. Make sure you use brake fluid which has not been hanging around for too long.
Offline Waspy
« Reply #9 on: 31 July 2013, 11:15 »
Great, thanks, ill be using a new bottle. It's DOT4 yeah?
