Golf mk3
hardmonkeys
what coolant best to use and how much would i need from empty.
Topic: what coolant best to use and how much would i need from empty. (Read 3223 times)
search
28 July 2013, 14:57 »
Had to change my thermostat so now need coolant.
Cheers.
1.6 mk3
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Foreveryoungaus16v
Re: what coolant best to use and how much would i need from empty.
28 July 2013, 15:08 »
G13 Coolant 3 litres 50/50 mix with water which will mix to 6 litres in total.
KW V2, TEAM DYNAMICS PRO RACE 1.2, EIBACH ARBS, DS 2500 PADS, BLACK DIAMOND DISCS, LIGHTENED FLYWHEEL, CHIPPED ECU, VIBRA TECHNIC MOUNTS, JETEX DECAT, FULLY POLYBUSHED
163 BHP (TSR POWER RUN)
VW BUSH
Guest
28 July 2013, 15:21 »
G12 ready mixed in 5lt containers about a fiver from ecp, just top up with a bit of water when its settled
Foreveryoungaus16v
28 July 2013, 15:29 »
G13 is same as G12 mate. Just newer version.
F17BAD
Forum addict
Golf MTM S3 GTI TURBO
28 July 2013, 18:52 »
G12++ is what u want
3 liters, then 3 liters of water too
Not no ordinary GTI....
www.mixcloud.com/kells/
Foreveryoungaus16v
28 July 2013, 19:19 »
My local Vw sells G13 now. As already mentioned its the same as G12++ just more environmentally friendly. Either will be fine
Last Edit: 28 July 2013, 19:25 by Foreveryoungaus16v
Therusterman
GTI forum regular
Reply #6 on:
28 July 2013, 21:09 »
Recently overhauled the cooling system on my vr, went to VW and there system showed g12++ has been superseded by G13. But you could still go for the stuff ecp sell with no problems
Foreveryoungaus16v
Reply #7 on:
28 July 2013, 21:20 »
Yep. I have just ordered 3 litres of G13
WeekendMechanic
Here all the time
Golf MK3 GTD
Reply #8 on:
17 September 2013, 15:30 »
On Haynes manual says 6.3 liters to be exact.
Golf mk3
hardmonkeys
