Author Topic: COILPACK #2 Continueous problem!!!!  (Read 1132 times)
Offline Dommy GTi
  • Dub fiend
« on: 28 July 2013, 08:46 »
Dub fiend
View Profile
 Personal Message (Online)
« on: Today at 08:43 »
Quote
 Modify
my car started running very bad when warm, never cold, but warm! and when it would get hot it will  judder quite a lot then power would kick in. now I plugged it in and it said coil pack b which was number 2, but after replacing that the problem still persisted.
so I changed all of them to see if I had got the wrong ignition coil that was going wrong but still same problem. ive been reading that it could be my ignition coil. yet this only happens when car is warming up. but we changed the coil pack over and the same message appears. which is the coil pack 2 error. ive heard ignition amps are expensive so I really don't want to go down that route!
what would your advise and ideas be of the problem? as I said, only gets very worse when warm! so id guess the ignition amp was out of the equation as im sure if it was that it would happen all the time regardless of the temperature.
bit of help please as I need my car for work :(
thanks alot
Offline ben.banks21
Re: COILPACK #2 Continueous problem!!!!
« Reply #1 on: 28 July 2013, 11:16 »
would help to tell us what car you have?
Offline Dommy GTi
  • Dub fiend
« Reply #2 on: 29 July 2013, 07:28 »
god knows why all the writing is there lol, problem is fixed, turns out a mechanic didnt change my spark plugs over at kwik fit so i will writing a complaint to their head office.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 30 July 2013, 19:10 »
a mechanic
kwik fit
this is your problem, these words should never be used in the same sentence
Offline Dommy GTi
  • Dub fiend
« Reply #4 on: 31 July 2013, 10:48 »
Lmao! Yeah ive been moaned at by my boys the fact i even went kwik fit, will not be happening again! cant believe he didnt change my spark plugs over and i paid for it! well guess i wont make the same mistake again.
