Author Topic: Grinding into 2nd  (Read 3780 times)
Offline curty409
Grinding into 2nd
« on: 27 July 2013, 00:44 »
Hi guys,
New here and I shall post to let everyone know who I am shortly but I'm looking to find out if any of you know what could be causing my gear problem in my mk4 gt gtdi.
When driving along obviously I go from 1st to 2nd but when I try and get 2nd it grinds, Now i first first it could be a damaged syncro but when looking to find out how much they are it seems that it is the same syncro for 2nd and 3rd. This confused me a little as 3rd gear will select fine as all my other gears.
Another thing OI noticed was that the clutch pedal vibrates a little when my foot is on it (bad habit of keeping foot on clutch). Not sure if that would help diagnose the problem or not. Wanting to get it sorted as soon as because skipping second and going third can be quite irritating to say the least.
Could it be a simple job of topping the oil up?
Don't really want to spend ££ on replacing all the trans oil to find out that wasn't my oriblem and waste my money.
Any help is appreciated.
Offline EsSeX dAn
Re: Grinding into 2nd
« Reply #1 on: 27 July 2013, 18:41 »
is it worse when its warm or just started up?
does it do it if you put itvinto gear slowly too?
i think i love you.....
Offline curty409
« Reply #2 on: 27 July 2013, 19:47 »
Will have to let you know tomorrow, been trying not to use 2nd so i don't damage the gearbox.
I have noticed though that if i let the revs drop it goes in better.
Offline EsSeX dAn
« Reply #3 on: 28 July 2013, 13:53 »
i think mines the actual linkage as it only does it in 3rd, i did originally think clutch but if it were, it would play up in all gears
Offline curty409
« Reply #4 on: 29 July 2013, 14:07 »
that's what I am hoping it is. Don't know how to sort linkage out yet but something I don't mind trying to sort out my self.
In reply to the previous reply, it doesn't particularly make a difference when changing the gear slow or fast. Also it seemed to change a little better cold than warm but didn't manage to get back to second again until it has warmed up, by that time I wasn't able to check cold 2nd gear changes etc.
Offline EsSeX dAn
« Reply #5 on: 29 July 2013, 22:35 »
could want an oil change
there is way you can adjust the linkage and swap a thing called the linkage tree thats meant to meant to help. mines only a little pain really so its just been left lol started being funny before xmas! and it hasnt deteriated
Offline curty409
« Reply #6 on: 29 July 2013, 23:21 »
Do you know what oil it is?
I've got 3 bottles of 75 90 lying around somewhere I think.
And if i could live with it then i would do, but trying build a bit of speed up isn't that easy going 1st to third. Especially when the exhaust is knackered too haha
Offline EsSeX dAn
« Reply #7 on: 30 July 2013, 22:04 »
i couldnt tell you as i dont know! i was gunna check the level on mine but literally that day on my way home the turbo seals went dumping all the engine oil down my exhaust lol oh and it was 3pm xmas eve to top it all!
can you not get it into second atall?
Offline curty409
« Reply #8 on: 01 August 2013, 13:34 »
I can get into 2nd but it just grinds all the way in.
It's as if the clutch doesn't open fully to let the gear change.
It's baffling me, also noticed a huge increase of power in the mornings.
Seems that my turbo isn't working all the time.
