Author Topic: Considering doing something...  (Read 1073 times)
Offline Rod1-gti
« on: 25 July 2013, 21:00 »
Im hoping to buy a second engine to build a forged 20vT. I was wondering if;
a) The aum head will mount to an apk block.
b) Is it worth the hassle?
Offline Nino
Re: Considering doing something...
« Reply #1 on: 25 July 2013, 21:09 »
I thought the AGU bottom end was forged?  :huh:
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Rod1-gti
« Reply #2 on: 25 July 2013, 21:16 »
I want to fit low comp wossner pistons and arp rods and bolts.
Offline Rod1-gti
« Reply #3 on: 25 July 2013, 21:18 »
Ill do it to the aum bottom either way but wanted to know if the aum head will fit the 2.0 bottom and if its worth doin for an extra 200cc
Offline Nino
« Reply #4 on: 25 July 2013, 21:20 »
Honestly I really know bud. I'm sure someone will be along with an answer :)
Offline ben.banks21
« Reply #5 on: 25 July 2013, 22:25 »
the apk wont match up to a 20vt head but you can use the newer fsi engine bottom end with crank and rods but not pistons, so you would have to get bigger pistons. or you could rebore your current 1.8t to a 2.0 and use a fsi crank on that.
but tbh the 16v head flows better than the 20v head anyway. so you might as well do a 2.0T 16v engine swap which in my opinon is easier and more cost effective.
« Last Edit: 25 July 2013, 22:27 by ben.banks21 »
