Author Topic: Mk4 not starting, another problem  (Read 820 times)
Offline luke
  • When in doubt, whip it out!
« on: 25 July 2013, 20:35 »
Fitted new fuel pump today, still won't start, wired battery to fuel pump and works, but then when in the car it doesn't start, also upon taking a fuse out to check the fans kicked in and went off when fuse is back in
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
Offline james2
  • No scammers please.
Re: Mk4 not starting, another problem
« Reply #1 on: 25 July 2013, 20:41 »
put a new crankshaft sensor in ?
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline luke
« Reply #2 on: 25 July 2013, 20:49 »
Crank sensor is working fine, vagcom came up with to do with injectors being starved
