Author Topic: Post Cat Lambda Spacer  (Read 4858 times)
Offline DubAndDubber
« on: 23 July 2013, 18:47 »
Fitted my decat a few weeks back and didn't sort out the lambda issue.
What do I need to do to remove the EML?
I've read that some kind of spacer does the trick, or washers?
Any help would be great.
Thanks
Mk5 Golf Gti 06'
Offline ben.banks21
Re: Post Cat Lambda Spacer
« Reply #1 on: 23 July 2013, 18:51 »
get it mapped out. i now if you use a spacer on the agu pre cat sensor the car runs very lean.
« Reply #2 on: 23 July 2013, 19:30 »
I have an AUM. Already had a map too.
Mk5 Golf Gti 06'
Offline Granta Gti
« Reply #3 on: 23 July 2013, 19:43 »
You shouldn't need to space a pre cat  :undecided:
Offline navmk4gti
« Reply #4 on: 23 July 2013, 21:34 »
I had decat on my agu was fine..no lights nothing  :undecided: as for aum map it out
« Reply #5 on: 23 July 2013, 21:38 »
I'm hoping Dom will come along and help me out...
Mk5 Golf Gti 06'
Offline dom
  • Back in a Mk4
« Reply #6 on: 23 July 2013, 22:06 »
You called? :grin:
I'm lucky in that my decat hasn't thrown the EML on. You have 2 options, first is to have it mapped out, second is to space the post-cat lambda, not the pre-cat one as has been suggested.
The pre-cat one controls fuelling, post-cat just checks that the emissions are within an acceptable range and isn't really needed. By spacing the post-cat sensor it will read the emissions to be lower than they actually are, therefore in most cases preventing the EML from coming on.
Something like this...
http://www.ebay.co.uk/itm/LAMBDA-O2-OXYGEN-SENSOR-BOSS-EXTENDER-SPACER-FOR-DECAT-FROM-HIGH-GRADE-STEEL-/161046047401?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item257f17aaa9
I'd check the thread is correct before buying though, use your cat if you still have it :wink:
Offline ben.banks21
« Reply #7 on: 23 July 2013, 22:10 »
i had to on my agu because the 3" straight through Exhaust system i brought from the US had the lambda sensor hole on the downpipe too close to the fire wall so i had to buy a 90 degree spacer which in turn caused it to run very lean.
Offline dom
  • Back in a Mk4
« Reply #8 on: 23 July 2013, 22:15 »
It will have been running lean due to the false reading, was it a cheap decat? I'm running a 3" one from the US and had no such issues.
« Reply #9 on: 23 July 2013, 22:16 »
Thanks Dom! I remember reading through your dub rides section, but I wasn't searching through it to find out  :grin:.
Thanks for that, the car isn't driving bad, if anything it's better. But that bloody light drives me nuts!
Mk5 Golf Gti 06'
