Author Topic: Po171 system to lean bank 1 fault code??  (Read 1269 times)
Offline 150+
« on: 22 July 2013, 07:53 »
Just plugged my car in to my pals computer and this came up have done some searching not found much
Any ideas
Offline Agreeable Slick
  • Unit
Re: Po171 system to lean bank 1 fault code??
« Reply #1 on: 22 July 2013, 12:59 »
Lambda sensor is playing up pre cat.
Two options,
1) take it out and thrash the granny out of it for a bit to make sure that it isn't just covered with crap. (google italian tuneup)
2) Swap the dodgy front sensor out for something that is either proven to work or a new one and off you trot.
Offline 150+
« Reply #2 on: 22 July 2013, 13:43 »
Would the decat I have on it make any diff
  • Unit
« Reply #3 on: 22 July 2013, 13:50 »
Well, have they / you put the lambda back in after swapping? They are a bit fragile so you could have just knackered it by banging it around when swapping it out.
Offline nottyash
« Reply #4 on: 28 July 2013, 09:34 »
I had the exact same problem. It was intermittent.
We presumed it was either a breather hose or an o2 sensor.
After testing the sensor on a diagnostic tool it was functioning fine. Then checking hoses we found one split.
I replaced it with this one, so it wont happen again:
http://www.ebay.co.uk/itm/150977908303
« Last Edit: 28 July 2013, 09:39 by nottyash »
2002 51 Golf GTI 1.8T Black
2002 02 Golf GTI 1.8T Blue
2003 53 Ford Mondeo ST 220 Estate Blue
2004 54 Mini Cooper S
Offline 150+
« Reply #5 on: 28 July 2013, 09:40 »
I take it it was split??
Offline 150+
« Reply #6 on: 28 July 2013, 19:23 »
Sorry didn't read the bottom line properly :whistle:
Cheers mate will get it scanned again and Check the hoses
