Author Topic: Springs and shocks  (Read 2846 times)
Offline boneybradley
  • Back in a Mk3...
Re: Springs and shocks
« Reply #10 on: 25 July 2013, 09:38 »
So basically I need 4 shockers with bump stops rubber boots spring plates top mounts and bearings plus nuts for the front top mounts
Anything else ??????
you don't need the spring plates, plus if your not going very low why not use your current bump stops and boots? (you can trim the bump stops down if lowering)
Offline dibs1980
« Reply #11 on: 25 July 2013, 10:19 »
Can you swap the bump stops and boots from the coil overs?
I thought they would be different sizes
  • Back in a Mk3...
« Reply #12 on: 25 July 2013, 19:26 »
you will find most "budget" coils use standard set up boots and bump stops, and tbh you would be cutting/modding the std one's anyway
Springs caps may be different but again it depends on the coilies
