Author Topic: Springs and shocks  (Read 2847 times)
Offline dibs1980
Springs and shocks
« on: 21 July 2013, 21:57 »
Hey people
Just a bit of info required
I'm currently running coil overs on my 97 mk3 golf 2.0 8v but I'm looking to get new shocks and springs.(undecided on standard or after market)
Basically what do I need to go with the shockers?
Is it just bump stops,rubbers boots,spring plates,top mounts and bearings??or are there washers as well
Wayne
Offline search
Re: Springs and shocks
« Reply #1 on: 22 July 2013, 17:30 »
Springs, dampers, new top mounts would be best, do you have your old suspension as you could use all the nuts n bolts of that.
you will need a compression tool unlike the coilovers that don't need this tool.
May i ask why you're changing from coilover to shocks? just i'm looking into getting coilovers or shocks. (i've always had coilovers)
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline dibs1980
« Reply #2 on: 22 July 2013, 18:39 »
The coil overs just seem a bit hard and I think there cheap ones and there starting to make a noise
When I bought the car I never got the standard shocks that's why I was asking what I needed
Thanks for the reply
Offline dibs1980
« Reply #3 on: 22 July 2013, 18:46 »
There's a set of blistein shocks on eBay I was looking at and maybe get 30mm lowering springs or just go standard
Offline gazareth
« Reply #4 on: 23 July 2013, 18:54 »
 a 30mm drop is a good compromise. only problem is if a spring breaks you will need to buy a whole new set. but I doubt that ever put anyone off lol.
Offline Foreveryoungaus16v
« Reply #5 on: 24 July 2013, 19:22 »
I agree, 30mm seems the best set up. Especially for handling.
163 BHP (TSR POWER RUN)
Offline dibs1980
« Reply #6 on: 24 July 2013, 19:42 »
So basically I need 4 shockers with bump stops rubber boots spring plates top mounts and bearings plus nuts for the front top mounts
Anything else ??????
Offline gazareth
« Reply #7 on: 24 July 2013, 22:31 »
I think I would just buy some good second hand ones complete and throw them on. sure you would find some at reasonable cost.
Offline dibs1980
« Reply #8 on: 24 July 2013, 22:54 »
Yeah that's probably the best thing to do ill just need to find a set now
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #9 on: 24 July 2013, 22:57 »
Local breakers or e-bay should be loads on there  :lipsrsealed:
2000 Mkiv GTi 1.8T AGU
