Author Topic: Slight vibration of brake pedal.  (Read 872 times)
Offline UnCl3RoRy
  • Silver - 2001 1.8T AUM
« on: 21 July 2013, 15:37 »
I noticed it a couple of days, so i thought it would be the pads or discs.
I got the fronts changed for mintex pads and discs.
But even after having the pads and discs swapped it still there, any ideas what it could be? It obviously stops fine, just slightly concered. At low speeds you dont really notice, but at higher speeds with harder breaking you can.
Any ideas?
If you no longer go for a gap that exists, you are no longer a racing driver - Ayrton Senna
Offline gazareth
Re: Slight vibration of brake pedal.
« Reply #1 on: 21 July 2013, 19:00 »
hi does it make steering wheel wobble? if not it could be back brakes causing it. once your up to speed try pulling the handbrake up slightly (very slightly!)  and see if it happens then. best to do it on dry road though.
Offline UnCl3RoRy
« Reply #2 on: 21 July 2013, 21:58 »
thanks for the reply. no it only the brake pedal that vibrates not the steering wheel, il try that, lots of empty roads round my end.
thanks
