Author Topic: need some advice on upgraids  (Read 3701 times)
Offline 52GTIPETE
Re: need some advice on upgraids
« Reply #10 on: 19 July 2013, 22:29 »
Lol it kept coming up on mine. If its wrong guys I stand corrected.  :shocked:
Offline barrym381
« Reply #11 on: 19 July 2013, 22:42 »
17705 is just a bug, rtech remove it with the map.
an if a pipe is split  :undecided:
Offline shiloh
« Reply #12 on: 19 July 2013, 22:49 »
Drove the car again today, seems to be surging a bit, kind of feels like the clutch is slipping only it isnt the clutch (car has less than 28K on it and the revs arn't jumping up) Anyone any ideas? Should probably get this fixed before the remap, could this be throttle body too? MAF sensor is one of the newer ones, not sure when it was replaced but was fitted with the 5 star bolt instead of 6 could be the other way round but definitely a newer maf.
Offline DubAndDubber
« Reply #13 on: 19 July 2013, 23:56 »
I'm sure it's 90% bug, 10% leak.
Mk5 Golf Gti 06'
Offline barrym381
« Reply #14 on: 20 July 2013, 00:00 »
a must of been the unlucky 1 then  :laugh:
Offline shiloh
« Reply #15 on: 20 July 2013, 17:58 »
Think I'm going to take it to wallace performance or motorwerks in aberdeen unless anyone knows anywhere better? Is there a big difference after the remap?
Offline barrym381
« Reply #16 on: 20 July 2013, 19:03 »
wallace performance will prob be your best bet  :wink: try blag a run in there evo
Offline james2
  • No scammers please.
« Reply #17 on: 20 July 2013, 19:08 »
Its a AUM thing.  AGU  :cool:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline golfyste
  • Project track car
« Reply #18 on: 21 July 2013, 07:55 »
I'm sure it was only a big after being remapped?? And if its on a standard Ecu car then it will be genuine
« Reply #19 on: 21 July 2013, 16:50 »
Apparently it's a bug in the standard ecu. When rtech mapped my car they removed the code.
Mk5 Golf Gti 06'
