Golf mk2
Oil on plugs?
Topic: Oil on plugs? (Read 3135 times)
devilscaff
Here all the time
allways up for alaugh
Oil on plugs?
18 July 2013, 18:00 »
I'm getting oil deposits on two of my spark plugs, the plugs are only 500 miles old but look knackered. Also it's been a bit lumpy when cold. Thanks
dragonfly
Re: Oil on plugs?
18 July 2013, 19:29 »
What car?
devilscaff
Here all the time
Re: Oil on plugs?
18 July 2013, 20:25 »
Mk2 16v should if said that really , whoops
dragonfly
Re: Oil on plugs?
19 July 2013, 11:07 »
Have you torqued them up correctly?
devilscaff
Here all the time
Re: Oil on plugs?
19 July 2013, 15:06 »
No don't have a torque wrench
dragonfly
Re: Oil on plugs?
19 July 2013, 19:54 »
Try to just nip them up a bit more and see if that cures your problem. Are the threads wet with oil? If so it could be the cam cover gasket.
Last Edit: 19 July 2013, 19:56 by dragonfly
Diamond Hell
Serious forum addict
Opinions я Us
Re: Oil on plugs?
Reply #6 on:
19 July 2013, 21:50 »
£10 says it's the cam cover gasket leaking into the plug holes, which is also causing shorting issues which is why it is running lumpy.
devilscaff
Here all the time
Re: Oil on plugs?
Reply #7 on:
19 July 2013, 22:09 »
That's sounds plausible it looks quite simple to change the rocker gasket or am I being over confident?
Diamond Hell
Opinions я Us
Re: Oil on plugs?
Reply #8 on:
19 July 2013, 22:12 »
Simple job, just make sure it's properly clean and zig-zag around the bolts WITH a torque wrench - if you over-tighten them it will leak again.
devilscaff
Here all the time
Re: Oil on plugs?
Reply #9 on:
19 July 2013, 22:55 »
Gonna have to put that on the list, spending too much time cleaning me new ed35. I'll order the part, when work and family life quieten down iv promised myself a day on the car.
Golf mk2
Oil on plugs?
