Author Topic: Whats this clip called ?  (Read 4498 times)
Offline Ady TDI
« on: 18 July 2013, 17:29 »
Hi
Can anyone tell me what this clip is called ? This pipe keeps popping out so think i'm going to try a new clip, also anyone know where I could get one cheap ?
Thanks
Offline Rhyso
Re: Whats this clip called ?
« Reply #1 on: 18 July 2013, 22:39 »
Dealer only part and if it keeps popping out then chances are the lugs on the pipe are worn
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2 on: 18 July 2013, 23:55 »
What Rhyso said.
Get an EGR delete  :wink:
Offline Ady TDI
« Reply #3 on: 19 July 2013, 09:44 »
Thanks guys,
Had someone do a scan (not vag com) and said EGR problems, reset the fault but hasn't come back, but the clip seems loose so hoping just the clip, will GSF not sell it ? What is it I ask for ?
Offline Rhyso
« Reply #4 on: 19 July 2013, 11:00 »
Thanks guys,
Very much doubt they will but you can try  :undecided:  Its simply called a clip AFAIK; just show the parts people the pic and they will be able to find it on the parts list  :smiley:
Check the lugs on the pipe but I suspect they are worn; common problem sadly  :sad:
Offline scarr89
« Reply #5 on: 19 July 2013, 11:54 »
If you have EGR problems just do the EGR delete. So easy and very effective.  :smiley:
Darkside do a cheap kit.
Offline Rhyso
« Reply #6 on: 19 July 2013, 18:24 »
Does the Darkside kit do away with that pipe then?? Otherwise it wont solve the problem as the pipe will still be there
EDIT - see how it works now  :nerd:
What engine is yours? You may get a warning light on the dash if you do the delete. It can be mapped out though
« Last Edit: 19 July 2013, 19:24 by Rhyso »
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 20 July 2013, 21:45 »
Your egr valve will be covered in soot most likely.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Ady TDI
« Reply #8 on: 22 July 2013, 13:09 »
Engine is ARL, I am in the process of cleaning my engine with some Gunk green  :whistle:
« Last Edit: 22 July 2013, 13:24 by Ady TDI »
