Golf mk6
Snoopy
Miltek fitting the standard exhaust??
Topic: Miltek fitting the standard exhaust?? (Read 2485 times)
MBCGTI
GTI forum regular
18 July 2013, 04:19 »
Can anyone tell me whether a rear non resonated milltek back box for the standard exhaust or do you have to cut and weld it??
Marshy
Guest
Re: Miltek fitting the standard exhaust??
18 July 2013, 09:36 »
If you wanted to change only your rear silencer for a Milltek one then you'd need to cut your original but would require a reducer as there will be at least 1/4 inch difference in pipe diameter.
MBCGTI
GTI forum regular
18 July 2013, 16:06 »
Well I was hoping that wouldn't be the answer. There is a rear box for sale on e at but can't justify spending money if that's the case.
wigit
18 July 2013, 16:11 »
your original zorst is in two sections, a milltek catback (with reducer) will replace the rear section, i cannot see why you would cut this
miltek rear sections are in two parts to reflect silencer options
Marshy
Guest
18 July 2013, 16:16 »
The standard exhaust should be in 1 piece right to where it joins in the tunnel under the handbrake area.
The Milltek is usually a centre section then a rear section joining at the rear axle area.
MBCGTI
GTI forum regular
18 July 2013, 16:45 »
http://www.ebay.co.uk/itm/231016233928?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
This is the item thats for sale, I assume its quite a bit of work for not much increase??
Marshy
Guest
Reply #6 on:
18 July 2013, 17:04 »
Anythings possible but you'd need some additional pipework made to make it fit.
Some exhaust places could probably make you a pipe and fit it for £50 or so.
You'd gain a bit more noise without the rear silencer but no power gains.
mkviken
Reply #7 on:
18 July 2013, 17:34 »
just buy mine and have done with it
Golf GTI 7.5 230 white silver
MBCGTI
GTI forum regular
Reply #8 on:
18 July 2013, 18:08 »
I want it but can't justify that amount at the moment as potentially going to be selling it due to buying a project house. I'm tempted to get it remapped and an exhaust before I do albeit will probably make me keep it.
wigit
Reply #9 on:
18 July 2013, 18:11 »
that is just the end section of the race system (without silencers), you can see from here what you are missing
http://www.millteksport.com/media.file.cfm?fileid=780#.Uegg35WqBbw
Golf mk6
Snoopy
