Author Topic: mk2 rear bearings  (Read 1613 times)
Offline caddygti
mk2 rear bearings
« on: 17 July 2013, 21:39 »
thread had gone on disk for wheel bolts so ordered a new disc from vw heritage, when it came to fitting it I planned to swap over the original inner bearings but they didn't fit right,was right loose, so bought a new bearing set to match the new disc but just wont seem to fit into the disc as if its too big is there a nack to getting em in?
cheers
Offline gazareth
Re: mk2 rear bearings
« Reply #1 on: 17 July 2013, 21:52 »
sounds like you got a dodgy disc. even a used bearing should be a tap in fit in a new hub/disc. is it definately the correct bearings? same number on them?
Offline Simeon
« Reply #2 on: 18 July 2013, 12:08 »
Are you fitting the bearing race?
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 18 July 2013, 12:44 »
This!
You are putting in ALL of the bearing aren't you...
Unlikely the parts are wrong, but it can happen
Thom
