Author Topic: Problem turning over after sump refit  (Read 1278 times)
Offline Jammin787
« on: 15 July 2013, 20:33 »
Ive recently fitted a new sump on my mark4 golf. I mounted the Kurb and managed to take a chunk out the old one. Fitted a new one and now the engine won't turn over. I've had my mate have a look at it and he wreckens the engines seized! Any chance it could be something?? Thanks for any advice.
Offline gazareth
Re: Problem turning over after sump refit
« Reply #1 on: 15 July 2013, 22:49 »
hi did you check the oil pick up pipe wasn't pushed up in to the crankshaft? for a quick test get a spanner on the crank pulley centre bolt and see if it will turn backwards slightly. careful of your timing belt jumping though!
Offline Jammin787
« Reply #2 on: 15 July 2013, 23:52 »
Alright mate. No I never checked that, probably worth a look then and I'll do what you suggest with the crank. Fingers crossed. Cheers mate
