Author Topic: Need help identifying a plug on 1.8T engine loom  (Read 1198 times)
Offline CheshireSport
« on: 14 July 2013, 15:27 »
After some help identifying what a plug is for in my engine bay.
The engine/engine loom is 1999 T reg 1.8T, the plug in question has the same part number as the headlight plugs (but it isnt for that). It is part of the engine loom and is near the plugs for the altitude sensor, and the 2 plugs that plug into the airbox.
Heres a few pics.
Its location on the loom
The distance between it and the altitude sensor & Airbox plugs
Now the actual plug in question
WANTED: O/S R32 HEADLIGHT REAR COVERS
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Need help identifying a plug on 1.8T engine loom
« Reply #1 on: 14 July 2013, 16:25 »
Isn't there some sort of module that clips to the inside wing behind the passenger side headlight?
« Reply #2 on: 14 July 2013, 16:32 »
This plug is too far from the passenger headlight.
Its been suggested that it might plug into the "lower" loom on ukmkiv's. Do you know if the engine loom actually plugs into the main car loom in the engine bay? It would make sense if it does.
Been such a long time since i stripped this car down
Offline Chris.
« Reply #3 on: 20 July 2013, 16:07 »
Connects engine loom to car loom and sends coolant temp, few lives, and oil pressure wire, earth and a couple others to the interior car loom/clocks.
Wont go far without it.
Early models were in the black trunking on left,   later down by the battery tray.
Click For Build Thread
