Author Topic: Anyone know resistance values for coilpack?  (Read 1686 times)
Offline Jasikasisback
« on: 14 July 2013, 09:50 »
I have been given a coilpack that is working according to the previous owner. I don't want to switch the one I have on now to check and was searching on the net for the resistance values but couldn't find any.
I have a TEMIC FHP Elmotor (Sweden) VW part number 6N0 905 104.
If I take the coil with the plug facing me I assume the on on the far right with a one above it is the power terminal and the other two (one is in the middle and another is above the a three on the plastic housing are the outputs? I used a multimeter set to 20k Ohms and got these values
1. Pin1 (far right) to Pin3 (far left)  2.39
2.Pin 1 to middle pin                     3.43
Then I tried the output pin that goes to the distributor
1. Pin 1(far right)- output pin -5.5
2. Middle pin-output pin         -4.15
3. Pin 3(far left) -output pin   -3.11
Just wondering if the coilpack is ok...(or at least the resistance is ok...)
Any help would greatly be appreciated...
VW BUSH
Re: Anyone know resistance values for coilpack?
« Reply #1 on: 14 July 2013, 11:18 »
Plug it in see if it works and compare the two sets of readings.
You dont have to remove the old one just hang the new one out the way on a cable tie
