Author Topic: noise from suspension  (Read 1706 times)
Offline willz94
« on: 13 July 2013, 19:07 »
went to get a cd got back up and i had hit the curb at a fair speed, theres a very irritating "doink dong doink" noise best way to discribe lol, sounds kind of like a knock mixed with a worn lower arm bush noise. The bushes on it are fine and i cant see any play in the top mount. any ideas? trackings now also way out too. thanks
noise happens over uneven service which is almost every surface :')
« Last Edit: 13 July 2013, 20:12 by willz94 »
Offline tweed
Re: noise from suspension
« Reply #1 on: 13 July 2013, 20:09 »
Snapped spring? f**ked ball joint
Offline willz94
« Reply #2 on: 13 July 2013, 20:11 »
spring looks fine ball joint looks fine, how can you tell if thats gone?
Offline tweed
« Reply #3 on: 13 July 2013, 21:15 »
Not by looking. Same with bushes.
Need to grab wheel and pull and push with force.
It can be any suspension mount on that side.
Check anti roll bar too
Offline gazareth
« Reply #4 on: 13 July 2013, 23:13 »
maybe you bent the strut? but I think if the noise is that bad it should be very easy to trace with it jacked up and running in gear. I wouldn't be driving it anyway until its had a once over.
Offline willz94
« Reply #5 on: 15 July 2013, 15:26 »
cheers guys ill pit the sparefront coils on in the week and new top mounts see if it goes otherwise ill do ball joints and the cheaper bit then finaly a lower arm, is it possible i bent that?
